24v battery setup and charging options for off grid setup
georget
Registered Users Posts: 2 ✭
Hi guys
I'm looking to build a 24v battery pack to run my inverter.
I have purchased 4PCS 3.2v 200Ah LiFePO4 Rechargeable CALB SE200AH Li-Ion phosphate solar battery
I was thinking of pairing them with 3 banks of 150 x 18650 , 4.2v per bank which will give me total 12.6v
I'm will be running a MPPT Off-Grid Pure Sine Wave Solar Inverter with 3000VA
Also have 3 strings of 3 x 190w solar panels
I will use a Victron Energy Battery Protect 12/24V-100A on the system.
Any thoughts would be appreciated.
Welcome to the forum @georget
Frankenstein, are you planning to create a monster? Seriously bad idea if what's being proposed is to series connecting different lithium sub chemistries of different capacity,, things could go wrong in a heartbeat resulting in fire, injury or even death,forget this idea.
Thanks for the advice
Much appreciated
