Trace/Xantrex SW4024 Inverters with SimpliPhi 3.8KW LiFePO4 Batteries - Setup
bdimambro
Registered Users Posts: 5 ✭✭
Hi,
I have 2 Trace/Xantrex SW4024 inverters that although are old are working just fine. I am replacing my bank of 20 year old Absolutyte IIP 24VDC batteries with 6 SimpliPhi 3.8 KW 24VDC batteries. Does anybody have the inverter set points for the SW4024 and these LiFePO4 batteries? I also will be installing the smart battery protect (x2) and the smart shunt.
Any help will be appreciated.
Brian
Brian
Google, Simpliphi use with Schneider inverters, there is a pdf available with all the information needed, you may want to consider a Schneider battery monitor if Xanbus communication between is useful to you, hustle a thought.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Thanks for the response mcgivor. I do have the SimpliPhi Schneider doc for their new SW4024 inverters. I have the original Trace/Xantrex SW4024s installed in 2005. Was wanting to know if the setpoints for new SW4024s translate exactly to the older Trace/Xantrex SW4024s for LIFePO4 SimpliPhi batteries.
Using the same values would make sense assuming it's possible, perhaps SimpliPhi could answer the question. The settings in the document were what I used as a guide when programming my newe style SW 2524 with a DIY LFP bank, FWIW.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
