solar panel for export
fatimyelly
Registered Users Posts: 1 ✭
hello
i am interested in buying:
- solar panels of 250 W
- solar panels of 300-350 w
- solar moto pump of 1100 to 1500 w
- solar pressor 750 to 1500 w
- submersible solar pump kit 600 to 3000 w
- also the voltage in the destination country is 220 v
- items are for well 100m-120 m deep
please help with where I can get these items in the US to export to africa
thanks
thanks
Where in Africa are you located? When shipping costs import duties and taxes are taken into consideration it may be better to source locally.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
