How to ground SunnyBoy 6000US inverters?
aluminumwelder
Registered Users Posts: 10 ✭✭
I've been trying to understand the instructions for wiring up a pair of older sunnyboy 2008 6000us inverters to a 10KW GT Residential picnic shelter about 35 feet away from the main 200a home panel. I thought I was supposed to have an 8' long grounding rod at the solar panels which was attached to the solar panel frames. But these instructions seem to suggest I need to run the 6awg grounding cable 35 feet back to each inverter??? My main concern is that the inverter's GFPD will work. Can anyone help me with correct wiring.
I currently do not have any wires attached to either A or B of these terminals. I have them grounded at the picnic shelter like photo shows.
Going to have to ask your inspector what he wants. I don't like to run an equipment/frames/mounting/Lightning Rod ground thru a box with household wiring. I'd rather take that lightning right to earth, not thru a box.
Where do you get #6 from?"we go where power lines don't" Sierra Nevada mountain area
any hardware store sells 6awg
In your design, where do you get #6?"we go where power lines don't" Sierra Nevada mountain area
not sure I understand your question? I got it from home depot. why doe sit matter?
I think Dave is asking what manual/NEC code is suggesting 6 AWG cable for grounding (not that I disagree with your choice--From the little I know)...
I suggest 6 AWG as a minimum for grounding to a ground rod/system lightning grounding.
"Real/Professional" lighting grounding systems (lightning rods, ground rods/plates, etc.) can use much heavier/braided cables.
#6 is the minimum size, you can go higher like #4. The reason is due to physical strength, smaller gauges are too flimsy. NOt sure where it is in NEC, but somewhere in 250 I guess. several sources state this> i think I read it here Photovoltaic System Grounding - Florida Solar Energy Center (solarabcs.org)
Yep... agree with your reasoning from that I have seen... Years ago (may still be true), for residential size main panels, 8 AWG was also allowed--As long as the 8 AWG was insulated cable (bare #8 was not allowed). But I still suggest #6 is a better solution for your reasons (and an article I found years ago did some research of lightning strikes in Germany (as I recall)--And there were examples of 8 AWG cables getting vaporized and few (or no) instances of #6 or heavier cables surviving).
Ground rod is Number 6 solid no conduit, or stranded with conduit for protection. That is not what I think you were asking. I think you are talking about the connection between the two ground bars or ground systems. For offgrid we want them connected but not any thicker wire than is required. Typically this is the size of the wiring out of the combiner, array wire size, or what the inspector wants, if it is inspected at all.
The point is if lightning does hit, we do not want to get it into the home any easier than possible. We do want the advantage of everything being at the same potential to not attract the strike. There are many opinions on all of this. Mine is born out of good experience for 100's of offgrid homes. For grid apps it is what the inspector wants."we go where power lines don't" Sierra Nevada mountain area
- 228 Forum & Website
- 618 Discussion Forums/Café
