Battery refractometer
alcatel99
Registered Users Posts: 31 ✭✭
https://www.amazon.com/Ade-Advanced-Optics-aaogabf100atc-Refractometer/dp/B00GDH4YCO/ref=sr_1_4_mod_primary_new?crid=I54OT2SMGM08&dchild=1&keywords=battery+refractometer&qid=1606404166&sbo=RZvfv//HxDF+O5021pAnSA==&sprefix=battery+refractometer,aps,286&sr=8-4
i just watched a youtube video using this instrument question i have is would this be more accurate than a regular Hydrometer.
Possibly. But there will be a variation of specific gravity between the top and the bottom of any battery. At least you can "stir" the electrolyte somewhat with a hydrometer, something I can't see using this device.Island cottage solar system with approximately 2300 watts of panels, 1kw facing southeast 1.3kw facing southwest. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 32nd year.
The refractometer is more accurate and is temperature compensating. It is important to stir things up as battery acid tends to stratify, I use my hydrometer for mixing 😇Off Grid, 4.5KW array, 9&6KW Gens, 6848XW inverter, Midnite Classic 150, 2 strings - 48V - Trojan FLA L16 2V, located in Talkeetna, Alaska
I really don't think your hydrometer "mixes" the electrolyte that much...just the amount above the plates and below the fill line. There's fluid all the way to the bottom of the case between the plates. That gets stirred by bubbling action during absorb phase.
I do bulb squeeze 3 times before my testing sample with the hydrometer, mix up the top most electrolyte.
- 234 Forum & Website
