"WIRING" XANTREX CONEXT COMBOX
ModestoBob
ModestoBob Registered Users Posts: 3
I HAVE A XANTREX CONEXT COMBOX, which was wired to my Xantrex system before I did a house remodel.  Now I've "lost" the wire leading from the Xantrex system to the combox.
Does anyone know a way to connect the combox to the system wirelessly?  I know you can go from the combox to a router, but what about coming off the SCP or system itself?
In the alternative, is there another "wireless solution for monitoring tht does not involve running a wire from the system to the monitor?
Thanks.
    The Xanbus uses a standard cat 5 ethernet cable, BUT is not ethernet. It has moderate power voltage on several pins and will fry ethernet gear connected to the Xanbus port.    Xanbus needs a termination plug at each end of the daisy chain, or signal reflections will inhibit operation.   So you are stuck getting an ethernet cable from the gear to a Combox.  And the combox has an ethernet connection that can run to a wireless router.   I use some high end wifi gear and get a good signal 200' from my power shed to office where I monitor things
    Dave Angelini Solar Expert Posts: 7,077 ✭✭✭✭✭✭
    The other way is to buy the conext gateway from Schneider. Combox is out of support life and the replacement gateway has on board Wifi in station mode.
  • joesolar
    joesolar Registered Users Posts: 1
