Battery Box
jgregoire687
Registered Users Posts: 2 ✭
I have have a small 100w panel with one 100AH deep cycle hybrid gel battery. My off grid cabin is visited about once or twice a month. My temps get to 15 degrees on a regular basis. The panel should stay free of snow. I am thinking of using a cooler as a battery box to best retain the heat. I have also thought of using a small heater that will turn off when the temp is above 77 degrees in the cooler.
Does this sound viable? What kind of ventilation should I have in the cooler?
Lead acid batteries suffer no ill effects when cold as long as they are fully charged, the best approach would be to fully charge thendisconnect the battery before leaving, this would ensure that nothing goes wrong in your absence, which is when things usually do go wrong.
The battery will warm up inside the cabin assuming it's heated, a battery box isn't really nessersary nor is the heater, the battery is sealed, only venting if overcharging is occurring.
McGivor,
Thanks for the reply. The cabin is not heated, except when we are there. We heat by woodstove. I was under the impression that the charge controller prevented the battery from overcharging, am I mistaken?
Thanks -
Yes that is correct, the controller is/should be designed to prevent overcharging, but given that the temperatures are low, thus resulting in low self discharge, along with extended absence, it would be better to disconnect everything to play it safe. Nothing worse than arriving to find things have failed due not being there, which ironically often is the case.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
- 228 Forum & Website
- 654 Solar Water Pumping
- 619 Discussion Forums/Café
