Anyone thought of adding a Electric vehicle charging station to their existing off grid system?
Really pointless to add batteries to charge a car after sun hours. Add another 5Kw of PV panels & charge controller and use your existing setup, or charge in town. The cost and wear/tear on a battery bank Pb or Li, is cost prohibitive I believe.
Blanknbart,
What you really need to do is define the power you need to harvest from your solar power system... Then do (at least) a back of the envelope calculation to figure out what it would take to support those needs.
For example, assume 25% of an 85 kWH Tesla battery bank charged every (sunny) day. Having a battery bank at home certainly allows you to charge at night and drive during the day--As most people probably use their cars. Charging options:
https://www.pluglesspower.com/learn/tesla-model-s-charging-home-public-autonomously/
Lets pick the smallest which is 120 VAC @ 20 Amps--Keep the solar system small... There may be options for charging a Tesla from solar panels directly--But I know nothing about them--And I wanted to support charging overnight.- 85,000 WH * 0.25 charge = 21,250 WH per day (1/4 charge)
- 120 Volt * 20 amps charging current = 2,400 Watt AC charging power
- Rough location Fresno California (hours of sun per day, facing south)
- 21,250 WH per day * 1/0.85 AC inverter eff * 1/48 volt battery bank * 2 days storage * 1/0.50 max planned discharge = 2,083 AH @ 48 Volt battery bank (nominal off grid starting point)
- 2,083 AH * 59 volts charging * 1/0.77 panel+controller derating * 0.05 rate of charge = 7,980 Watt array minimum
- 2,083 AH * 59 volts charging * 1/0.77 panel+controller derating * 0.05 rate of charge = 15,961 Watt array minimum
- 2,083 AH * 59 volts charging * 1/0.77 panel+controller derating * 0.05 rate of charge = 20,749 Watt array "typical" cost effective maximum
http://www.solarelectricityhandbook.com/solar-irradiance.htmlModesto
Measured in kWh/m2/day onto a solar panel set at a 52° angle from vertical:
Pick December as "break even" day (may need genset, or fewer electric miles per day during bad weather:Jan Feb Mar Apr May Jun 3.77
4.73
6.01
6.61
6.84
7.05
Jul Aug Sep Oct Nov Dec 7.14
7.10
6.81
6.17
4.56
3.72
- 21,250 WH per day * 1/0.52 off grid system eff * 1/3.72 hours of sun per day = 10,985 Watt array "December break even"
A 2,083 AH @ 48 VDC battery bank would support upwards of a 10-20 kWatt AC inverter very nicely--Perhaps look at 240 VAC charging (faster charging available).
A very quick back of the envelope calculation--Lots of details need to be worked out (including daily power needs, battery size/chemistry, etc.)...
At least it is a start and framework to start working out your needs & costs.
@BB. Thanks for the breakdown. I'll step up my research.
I use an off-grid solar system to charge an Audi Q5 plug-in hybrid. All of my local miles are run as an EV; the gas engine runs only on longer trips. This is the third plug-in hybrid vehicle I’ve used on my system, the previous being a Ford and a Honda.
The Audi uses an average of 0.44 KWh per mile in EV mode. Other vehicles, other ambient temperatures, other driving styles, etc. will use more or less than that. I run about 12 miles locally each day, so my daily electrical use is a bit more than 5 KWh. The Audi has a 14.1 KWh battery, so I’m using slightly more than a third of the capacity each day.
My solar system consists of 3000 kW of panels running power into a Magnum Energy PT-100 controller, then into 8 GC2 AGM 224A batteries, and then into a Magnum Energy MS-PAE 4024 inverter. The EVSE that sends power to the car is set for 240V@6A.
My solar panels have a serious shading issue, since I have chosen to not cut trees for full sun. I also live in an area east of Lake Michigan, which has abundant sun during the spring and summer and much less sun in the fall and winter. As a result, my solar system fully supplies the Audi with power for local travel during the spring and summer and the utility supplies most (but not all) power during the fall and winter. If my panels were in full sun all year, this balance would be very different.
I really like having the sun charge the storage batteries during the day so I can charge the car overnight when I’m not running around town. It take approximately 4 hours to charge the Audi with the parameters above. As you can imagine, this stresses the battery bank and I’m now due for new ones after just 3 years of use. This time around, I’m going with LiFePO4 and making some changes in the electronics for better battery management.
All in all, I’m a huge advocate of using either on-grid or off-grid solar power for an EV charging station. With just a little practical management of the power, it’s doable and fun.
here is a guy that charges his Chevy Volt off grid, he build a "bang-Bang" controller to only use excess capacity to charge his Volt.
https://www.gm-volt.com/threads/adaptive-solar-charging-hack.12082/#post-125819
We use our grid-tie system to charge our 2 Volts for the last 9 years. Worked out great for us. -
Too bad about the Volt. :'( I have friend with one who comes up and gets a free charge here. Pretty simple to use the AUX for this. Offgrid folks have been doing that (pumping water) since Trace put an AUX port on their Sine inverters in the 1980's
Still running the Leaf's?"we go where power lines don't" Sierra Nevada mountain area
- 234 Forum & Website
