Can the Schneider Electric Conext MPPT Disconnect RS (Rapid Shutoff) be used as a Combiner Box?
blacknbart
Registered Users Posts: 20 ✭✭
I've looked at other Combiner boxes like the Midnite Solar MNPV6 Disco (Disconnect) Combiner Box, but keeping all my equipment somewhat the same brand can I use a Conext MPPT Disconnect RS as a Combiner box?
Attached are my Layout plans and some Equipment descriptions.
I did not look at your drawings yet but is this to be inspected? Got to go!"we go where power lines don't" Sierra Nevada mountain area
Dave, Yeah it will be inspected, but the ground-mounted system will not require that type of shutoff. Currently, only roof-mounted systems will need multiple shutoffs. I was figuring why not just as long I can have it within a combiner box. I really like the Midnite Solar MNPV6 Disco, but was wondering about the Scheinder MPPt RS. After looking thru the description and manual I wasn't convinced that it was able to be a combiner. Just wondering.
If it is inspected you need to use it as it is designed. Using a listed device that is modified could cause inspection issues. You should drop me an email."we go where power lines don't" Sierra Nevada mountain area
- 226 Forum & Website
- 617 Discussion Forums/Café
