Temperature sensor reading sharing
latinhawk
latinhawk Registered Users Posts: 36 ✭✭
My Schneider sw4048 inverter has a temperature sensor and it reads fine. I just added a Schneider 60 150 mppt charge controller that has no temperature sensor. They are both daisy chained together and I thought that they would exchange temperature data but it looks like they dont. Is there a parameter on either or both that would make temperature sharing possible?
    Dave Angelini Solar Expert Posts: 7,088 ✭✭✭✭✭✭
    The network shares data of one sensor with all devices. Even if it is missing on one device it is being shared. It is a mistake to use more than one sensor as "undefined behavior" can result. This is in the manual BTW.
     You can measure the offset with a voltmeter and temperature reading to prove that it is working.
  • latinhawk
    Thanks. My worry came from the temperature reading not being listed on the controller side.
