Rectifier volt drop
mazza355
Registered Users Posts: 4 ✭
Hi all quite new to wind power and wonder if someone could answer my question.i have a 1000w 48v turbine connected to a 300ah 24v forklift battery.so a bit puzzled as not making alot of power . with the 3 phases not connected to rectifier I have good voltage 50+ volts but when connected to rectifier the voltage max's out at 20 volts on three phase side with good wind is this normal because of rectifier
If you simply connect a wind turdine to a 3 phase rectifier and then to a battery, the battery when charging, will clamp the rectifier voltage to the battery voltage. It's takes a mighty wind to get much power out of a wind turdine, and with your wind, your device may not be able to charge the batteries.
Ok thanks so what is a better way.can I use solar controller after rectifier.
You can't use a Solar Controller with a wind turdine. Solar controllers unload the power source (PV panels) when the batteries are full
Wind controllers start switching in large loads ( dump loads ) when the battery gets full, to prevent unloading the turbine, when Unloaded, will over speed and grenade itself, shedding blades that can fly half a mile.
https://www.youtube.com/watch?v=nShKqcfmF-U
https://www.youtube.com/watch?v=NLInrjUtFGI
Sorry should have stated I have a separate dump load circuit on the batteries.what other ways is there.
Those big turbines are geared are they as mine spin very rapidly in the wind
mazza355 said:Hi all quite new to wind power and wonder if someone could answer my question.i have a 1000w 48v turbine connected to a 300ah 24v forklift battery.so a bit puzzled as not making alot of power . with the 3 phases not connected to rectifier I have good voltage 50+ volts but when connected to rectifier the voltage max's out at 20 volts on three phase side with good wind is this normal because of rectifier
NOTE: When connected to the 3-Phase Rectifier, you are NOT measuring an AC Sine Wave.
What you really need to know is ...
How many AMPS are coming out of the 3 Phase Rectifier and into the battery bank ?
Without knowing the AMPS,
you cannot say, "... not making a lot of power ...", because you do not know the power.
What make & model is your 1000 Watt 48V Wind Turbine ?
