New Schneider 600vdc Mppt for 6kw+ solar
Dave Angelini
Solar Expert Posts: 7,119 ✭✭✭✭✭✭
Hmm - Is this the mythical two channel MPPT charge controller that Schneider has been working on?
Not yet available in any retail outlets as far as I can tell and no indications of price - wonder if it will replace the 80-600?Offgrid in cloudy PNW
Full Schneider system with 18 REC 420W panels, 100A-600V controller, XWPro, Insight Home, six Discover AES Rackmount 5kW batteries (with integrated heating), Slimline enclosure, Lynk II, AGS, H650, H2200, H3000 (Propane conversion on Victron AutoTrans with Gen Line 2 wire AGS on AC1), Kubota 4500, Onan 7500 (on second AGS and AC2).
Mppt - 100a - 600 volt is available at my supplier. I think the store will have it here in the next week. They may take your order and give you an estimated arrival date.
It is a single mppt that will allow very easy wiring and BOS on a 2 string array in the 6 to 8kw range. I think you are right that it might, down the line replace the 80 amp controller. There is no difference between the two other than higher rated components and a change in the cooling fans control algorithm."we go where power lines don't" Sierra Nevada mountain area
- 232 Forum & Website
