Need Better SOC Chart
pabloesguapo
Solar Expert Posts: 116 ✭✭
I replaced the battery bank yesterday. It was sooooo time. I bought 16 batteries from Costco, Interstate GC2, 6v, 210Ah @20h. It's a 48v system, so 2 strings of 8 batts, 410Ah. Budget was a HUGE issue. Price, out the door: $1570.83.
I can't find decent SOC info on this make/model. Interstate Customer service is no help. I found the attached chart online, which gives charging parameters, and way too basic for my taste, SOC for GC2-XHD, - HD and - RD, but not the straight GC2.
I'm wondering if the charge parameters and SOC are the same, or at least similar for the GC2. Is there a chart like this for the GC2 somewhere?
I'd like to have more detailed SOC information than the published 100%, 75%, 50%. I'd like to see 10%, or even 5% increments. Is there a way to extrapolate? (Is the equation linear or logarithmic?)
27 Kyocera panels, 6,500w
24 CG2 6v batteries, 48v, 630Ah
Midnite Classic 150 & Classic 150 Lite in "follow me" mode
(2) Outback fx3648 inverters
Generac ecogen 6kw backup generator
Mate3s
No chart attached !
Voltage is all I have. But Specific Gravity is the gold standard test. (at a specific temperature)
Here is a nice article that talks about how a generic lead acid battery state of charge vs voltage vs current charge looks:
http://www.scubaengineer.com/documents/lead_acid_battery_charging_graphs.pdf
Sorry. Here's the chart I found27 Kyocera panels, 6,500w
Generac ecogen 6kw backup generatorMate3s -
I use mikes chart it is very close to my findings .
The charge voltages are way to high in your chart for absorb and float im not sure about the EQ but it seams to high all so.I use sams club battery’s made by penn , my absorb is set for 59 v with 3 hours of absorb .Float 54 v eq 61.5
my battery’s like to be charged , they use a gallon of water every 2/3 months at night after charging they sit @ 75o in the am they are back down to 70oOut back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar . -
Thanks. Those numbers look more normal to me. I figured what I had was a little high.27 Kyocera panels, 6,500w
FYI, Interstate doesn't manufacture batteries. They relabel/distribute them. The Interstate GC2s they had at my local Costco last year looked like they were made by JCI. The case matched a Varta 300 208 000. That probably doesn't help, because JCI isn't good at publishing tech info, either.
mike95490 said:No chart attached !
This is the chart that I use every time I need to use one.
