Sma 240 micro inverters
Terry356
Registered Users Posts: 2 ✭
Test 1
Welcome to the forum Terry,
I found a manual for the SMA micro inverter:
http://files.sma.de/dl/18925/SMG-SB240-IA-en-12W.pdf
It appears that your first connection (from ac 240 VAC branch circuit) is to the "Multi-Gate" One per (maximum) 12 panel/inverter (series or "daisy chain) 240 VAC string.
Is your question can you connect directly to an AC branch circuit without using the "Multi-Gate?
- 232 Forum & Website
