Sma 240 micro inverters
Will a SMA 240 micro inverter run connected directly to the loads panel?
  • Terry356
    Terry356 Registered Users Posts: 2
    Test 1
    Welcome to the forum Terry,
    I found a manual for the SMA micro inverter:
    http://files.sma.de/dl/18925/SMG-SB240-IA-en-12W.pdf
    It appears that your first connection (from ac 240 VAC branch circuit) is to the "Multi-Gate" One per (maximum) 12 panel/inverter (series or "daisy chain) 240 VAC string.
    Is your question can you connect directly to an AC branch circuit without using the "Multi-Gate?
