Charge controller stops before batteries are charged and still full sun
WoodyM
Registered Users, Users Awaiting Email Confirmation Posts: 1 ✭
My Flex 80 controller has done this a few times now. During the day it will just stop sending amps to the batteries. This happens when the batteries are not full and there is still full sun. On the LCD status screen it will say "Charged" on the controller. After the first two times I replaced the breaker for the CC. It stopped for a bit but just did it twice in a week. Coincidentally, the last two times were during a heat wave.
This is for a off grid system/back-up that is tied to a critical load panel for the house. We've been using it to offset some electricity usage during the summer, it's been cycling daily then shut off from the house at night.
It could be internal heat causing the charge controller to shut down for safety reasons. I know the Midnite Classic is designed to reduce throughput to protect it's self if it get's too hot. Is your power center outside?
If that's not the problem, perhaps it's the voltage drop when solar panels get hot reducing the voltage to an unusable level. Could you give us some information about your array/setup? Voltage of battery bank and the series/parallel of your panels along with their VMP or cell count.
How do you know you are at full charge ?If I’m powering a load my cc bumps up Solar production to meet the load
when the load ends the controller reads charged until I reach float voltage then it reads float .
If I turn off my inverter at 1100 am I go to charged because there is no load , so more powerOut back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar .
