5x400w panels 24v system
Miyaksue
Registered Users Posts: 1 ✭
Howdy. I have 5 of those panels and such controller. Hoping to achieve a reliable 24v setup.
Can I please get advice as to how to wire the panels together?
Much appreciated!
Not a great combination, the charge controller may be damaged if you try to do a 2 in series in a string and 2 strings in parallel, You will want to see what you max low temperature is and likely 'cheat' and use Midnites string sizing tool to see if the voltage will run too high when you are near your max cold snap. When colt the panels VOC will rise at 47 volts per panel and a combined 94 volt VOLT in series, you won't be safe in very cold temps. Of course this only uses 4 of your panels,
Your charge controller will want more voltage than a single panel can provide.
Another option if you panels are near your battery bank, is to run all the panels in parallel and buy a 60 amp PWM (cheap) charge controller. You would typically want to use a combiner box and put each panel on a fuse or breaker.
