Misleading Amazon spot welder ad?
softdown
Solar Expert Posts: 4,062 ✭✭✭✭
Look at the accessory package featured in the photos. Quite impressive indeed. But I expect heartache upon receipt. If the buyer receives all the accessories this may be the best buy - of a huge array of choices. The photo includes even includes items to get you started in making a couple BMS.
But with no apparent sales - I suspect some shiftiness in the ad. The items are depicted twice. The buyer could likely get a refund upon return. Or not - Amazon is not the seller. Third party seller though they have an extensive product line to offer.
https://www.amazon.com/Mophorn-Battery-Welding-Soldering-Portable/dp/B07ZQHFYR7/ref=sr_1_46?dchild=1&keywords=spot+welder&qid=1596123652&sr=8-46
Hoping the posts about making lithium battery packs are welcome - more or less. Note that a poorly made lithium battery pack is potentially hazardous. This is not for anybody unprepared to spend a lot of time and some fairly significant money.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
Softdown,
The discussion is fine...
Probably do not do a bunch of separate threads/discussion. And put the posts in the "New Battery Technology" forum...
Most of our battery discussions in the Off Grid and Battery forum are for large format batteries to run a cabin or home... Not Flashlight/Power Tools.
I will move these threads to the NBT section.
Makes sense - though they will not get read - in my experience. No harm done.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
While there are not a lot of posts in the New Batt Tech forum, it seems to get roughly equal reading as the other forums... I think that the posts there are read--How many people reply to them--That is based on subject matter--Get more posting traffic in forum, probably more replies and new discussions too.
As a rough rule of thumb, The number of "reads" is roughly equal to 10x the number of post (in thread, forum, etc.) for the "average" subject.
I didn't even know that forum existed. I would think they would be discussing carbon or seawater or ? Carbon batteries are coming. Next great technology in my opinion. I may be using the wrong terminology though. Been awhile.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
