Does anyone have the Installation PDF for BP4175B (175W) Solar Panel?
You might check and see if those panels are subject to recall... I had the BP-175 panels, and they did fail, to be replaced with BP-175A -- They seem to work OK, so far, for me. But BP got out of the solar business(?)--However, they are (last I checked) still honoring warranty claims.
There is/was a court case over the failed panels
https://forum.solar-electric.com/discussion/350934/failed-solar-panels
http://www.bpsolarsettlement.com/
3. Which BP model numbers are included in this Settlement?The solar panels included in this Settlement are called “Class Panels.” Class Panels include all BP solar panels manufactured between 1999 and 2007 with an S-type junction box. This includes the model numbers listed below.
Please note: a new model number has been added, BP365TS, which was manufactured 2005-2007.
Category 1 (“FDK+ Panels”)
BP170I
BP175B
BP175I
BP3140S*
BP3160B*
BP170B
BP3160S
BP4170B
BP3150S
BP4175I
BP3165S
SX160B
SX170B
BP4175B
BP2150S
SX150B*
BPSX150S
BPSX3150S
SX150L
SX140S
BP5170S
SX150S
SX160S
BPSX3160S
BPSM3160S
SX4175S (a/k/a BPS4175S)
BP365TS
I probably would not bother installing these panels on a new installation.... Also, new panels are "cheap" and have a warranty.
The PV wire leads exiting the J-box on the rear of the panels had a terrible strain relief problem. If the wires got tugged to any extent it caused a broken or high resistance solder connection. Best to check the output of each panel with a multimeter, or better yet put a load on them and test them. Wiggle the wires while testing and look for voltage fluctuations.
Any panels that show any scorch marks under the glass adjacent to the J-box should be considered failed whether they have output or not.2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 460 Ah. 24 volt LiFePo4 battery bank. Plenty of Baja Sea of Cortez sunshine.
- 232 Forum & Website
