solar wire conncetors
robocop
Registered Users Posts: 120 ✭✭
Hi people
The mc4 and ac65 connectors are the same?
Robert
Robert
I could not find anything about AC65 connectors--Do you have a link?
I would guess it's not a legal pairing.
While they may "fit" only MC4 should be mated to MC4 from my understanding.
It's likely some mfg does not want to pay the trademark royalty to use "MC4" and they devised something to fit, but it will not be certified to mate with MC4
hi Bill
panel vmp is 58.95 imp is 10.87 voc 48.63
inverter : max panel array is 4000w pv array mppt voltage is 130vd max pv array open circuit voltage is 145vd
inverter is MUST hybrid 5.5kw and I do live in curacao.
What about the inter panel connections ? Should I use less panel? And what will the thickness be for 35 meter lengt
I do have 12pcs 250ah batteries to form 48v and 750 ah
Thanks for you attention and have a nice day
Bob
Bob, Is this the inverter/charger/solar controller (not sure--Lots of products)?
https://www.mustsolar.com/ph1000-series-onoff-grid-hybrid-solar-inverter-3-6-5kw/Maximum DC voltage(V) 580 MPPT voltage range(V) 120~550 Maximum input current(A) 11/11
I think I have the wrong one--These specifications are quite different than yours??? If you can justify the above inverter (high voltage Vmp-array), it would probably be a nicer fit your your 35 meter cable run (high voltage, low current array, smaller diameter copper wire needed)...
