MT50 Chaos
matthewmaday
Registered Users Posts: 1 ✭
I’m having difficulty deciphering the readings I am getting from the MT50. Specifically, and surprisingly, the battery icon. Does the icon really accurately reflect how much charge is left in the battery? It fluctuates a lot and seems questionable. I took a picture today (it is cloudy) and it appears to be almost depleted. It sometimes is almost depleted during during after a day of full sun and not depleted after a full night of usage. i have almost 2kwh of battery with a load of a few cellphones and two 6 watt lights. Logically, this makes no sense. I could be missing something. I just need confirmation to troubleshoot.
Thanks for all of your help
Mine never really work % of charge was not AccurateOut back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar .
Welcome to the forum @matthewmaday
The display is merely an indication during charging, not a true representation of battery state of charge, hence it may display a full battery in direct sunlight but drops a few bars when some clouds pass by. The better method to calculate capacity is by using a shunt based battery monitoring system which calculates what is taken out of the battery versus what is returned.
The MT 50 uses voltage which is, in itself, is very misleading, ~14.4V will indicate a full battery icon, as soon as the sun cannot provide any more energy the voltage will drop to its fully charged rest voltage, somewhere in the 12.7V regon thus indicating perhaps 3/4 on the display, this is normal for a less sophisticated type display.
This is merely an explanation of what you are perhaps seeing, your actual circumstances will depend on details such as array size location, loads an so forth.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
