48 Volt Panel Wiring
seant
Registered Users Posts: 9 ✭✭
I recently converted from 24 to 48 volts. When i converted, I had 10 panels. Thanks to the wind storm and a tree, I’m down to 6.
4-265 watt panels and 2- 250s
my bank is 8 487 Amp surretts connected to a power flex 80 with an aims inverter charger
its gonna take me about 10 days to get more panels in. What would be a good configuration with the panels I have left?
my run is about 80 feet and I’m using 6awg to CC
What is the Voc/Vmp/Imp of your panels?
What is your present minimum ambient temperature?
For a 48 volt battery bank, you want a minimum Vmp-array voltage of ~72 volts (standard conditions... And ideally around 100 VDC (again nominal). In warmer climates, you can get away with higher Vmp-array-std voltages.
Vmp (and Voc) falls temperatures rise. And your array voltages rise as voltages fall.
You probably are looking at 3x panels in series times 2 parallel strings (Vmp~30 volts, 3x 30 volts = 90 Volts Vmp-array-std). If your Vmp-std is different...
There is a good chance that if your 265 and 250 Watt panels have reasonably "close" Vmp and Imp (10% difference or less... I.e., 30 volts for one, 33 to 27 volts Vmp for the other, etc.) they are close enough to connect in series parallel.
It’s in the low 20s at night and hitting 50 during day. I live at 4000 feet so it rarely gets above 80 here
250 36.9 VOC 29.8 VMP 8.39 IMP
265 38.3 31 8.55
