Not sure what I have. 48v system
smckee
Registered Users Posts: 4 ✭
You have some 12V batteries, AC circuit breakers, terminals and a surge suppressor.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Can I use them to ac couple to my existing 2.2kw pv system. Grid tried SB3000 8 275's panels
The items are for the most part designed for AC distribution, aside from the batteries which in all likelihood are dead. AC coupling requires specialized equipment, so I'm going to have to say no, what you have is just a collection of parts, the batteries may have some value at a recycling depot.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
- 621 Discussion Forums/Café
