Batteries
mhw
mhw Registered Users Posts: 1
I have a very small remote cabin I use maybe a few times a year..It is set up with a 24 volt Outback invertor and charge controller..Want to change batteries and would like to know if 4-6 volt deep cycle would be sufficient..Thanks
  • 706jim
    706jim Solar Expert Posts: 526 ✭✭✭✭
    Four batteries should be fine.
    BB. Super Moderators, Administrators Posts: 33,714 admin
    It also depends on the output of the AC inverter, and what power levels you expect (and ideally, knowing the usage and solar array size).
    More or less, the nominal suggested max continuous load for a FLA Battery bank would be (assuming 6 volt @ 200 AH FLA batteries, 4x series, and C/8 discharge--8 hours from 100% to "Dead"/zero% SoC):
    • 24 volts * 200 AH * 1/8 hour discharge * 0.85 AC inverter eff = 510 Watt "average" load (maybe 2x that for short periods)
    Just trying to set expectations.
  • Marc Kurth
    Marc Kurth Solar Expert Posts: 1,190 ✭✭✭✭
    How long is a piece of string? :)
    Well, it depends on what you need.
  • petertearai
    petertearai Solar Expert Posts: 471 ✭✭✭✭
    A bit more info required . What are your present batterys . How old are they . What size PV .
    What are your loads ?
  • 706jim
    Hence my earlier answer.
  • softdown
    softdown Solar Expert Posts: 4,034 ✭✭✭✭
    It is somewhat likely that four 6 volt batteries will be what makes sense. The dearth of info to work with is nominally puzzling.
