Refrigerator Problems
southfork
southfork Registered Users Posts: 54 ✭✭
All of the power outages here in California has everyone buying Gen sets I've heard of a lot of problems with mother boards in refrigerators . What's going on here to small of generator ?
 24 solar world 285 watt panels with 24 Enphase 250 s ground mount grid tied .
  • Estragon
    Fridges can be a tough load on smaller generators, which can have pretty wide variations in voltage etc to begin with.
    Pity there aren't more inverter type fridges available in US/Canada.  With much lower startup loading, they'd be more generator friendly.  I don't know if this is the issue, but brown-outs are hard on loads.
    Ran my in-laws' home for several days on a Honda eu2000i with a extended runtime fuel cap and 5 gallon gas can (something like 2-3 gallons per day) because of wild fire warning power shut down. 2x "modern" (computer based) refrigerators plus a garage freezer, a 1/3rd HP fish pond pump, pond air compressor, and a few other small things around the home...
    Genset was new in box (bought 6+ years ago for emergency backup).... At first, had to run with ECO mode switch off... But after a day running (and adding pond water pump), could run with ECO mode one just fine (originally would stall when hit with fridge compressor load).
    No problems.
    A Honda eu2200i (new version), or eu3000i should run everything (within reason) just fine.
  • Graham Parkinson
    Graham Parkinson Registered Users Posts: 195 ✭✭✭
    We run our LG 19 Cu ft side by side fridge (purchased from Lowes Canada), bottom freezer Inverter Fridge on our Ryobi 700 Watt propane generator no problem at all (also a gazillion LED lights)
    Offgrid in cloudy PNW
    Full Schneider system with 18 REC 420W panels, 100A-600V controller, XWPro, Insight Home, six Discover AES Rackmount 5kW batteries, Slimline enclosure, Lynk II, AGS, H650,  H2200, H3000 (Propane conversion on Victron AutoTrans with Gen Line 2 wire AGS on AC1), Kubota 4500, Onan 7500 (on second AGS and AC2).
  • southfork
    edited January 2020 #5
    Nice to hear we just purchased a 24 cf LG . bottom freezer from Best Buy .
