RV curved roof mounting...
My new RV has a curved roof, and I have 320w panels with "Z" type mounting feet with 3 holes for roof mounting. They recommend using "shims" on curved roofs. I assume all hardware should be stainless, so what would you use for shims to compensate for the curve?
4.8kw Grid Tied Array
840w Battery Backup array
640w camper array
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,138 ✭✭✭✭✭
    I'd use aluminum to shim between the panel frame (aluminum) and the Z bracket. I see no reason to have to use stainless shims.
    Be aware that stainless steel bolts and nuts can be an issue... Depending on the grade of SS, Stainless on Stainless threads tend gailing and binding (and lock, you will twist/snap the bolt before the threads give-way). Better to use Stainless and Brass, or Brass on Brass... If still using stainless sets, use anti-seize compound on the threads.
  • littleharbor2
    Not to say that doesn't happen but from my experience I've found very few stainless bolts that have seized , probably less than 1% of the many thousands of bolts on old arrays I have dismantled. When they do, you definitely will end up snapping  or having to muscle them to get them apart.
  • Terry
    Terry Registered Users Posts: 3
    edited December 2019 #5
    Thank you for the reply's.
    littleharbor2: That makes sense. But exactly what would these shims, apparently designed to apply a tilt to match the roof curve, and maintain a solid connection look like? Are there washers that gradually become thicker across their diameter?
    BB: The panel mounting hardware is supplied with the Z Feet, but nothing that looks like a "shim".
    640w camper array
    leveling washers:
    Commonly called beveled washers, these are tapered to fit inside an I-beam's flange to provide a parallel bearing surface.
    18-8 stainless steel washers have good chemical resistance and may be mildly magnetic.
    Hot-dipped galvanized iron washers are corrosion resistant in wet environments.
    Aluminum washers are lightweight and corrosion resistant in wet environments.
    https://www.mcmaster.com/standard-washers
  • littleharbor2
    We may be thinking differently as to the application of the mounting hardware. I'm visualizing straddling the curved surface with the panel and mounting the z brackets along the two edges that would be parallel to the roof. The shims would just make the z brackets a little taller, keeping the frame from actually hitting the roof surface at the peak of the roof. That was your issue, I thought.  If the direction your panel is mounted at would put the long sides of the panel doing the straddling I would add an extra bracket of some type on either side of the panel where it spans the peak.
  • Estragon
    I've used scrap bits of composite decking as shims.  It's UV stable, doesn't corrode or rot, and is pretty easy to work with common woodworking tools.
