I need to setup a Hot Spot outside, Work arounds on Charging Lithium batteries In sub-Freezing?
Photowhit
So I lost my sweet deal with my one neighbor who has moved in with her daughter.
I've got a MiFi by Verizon, I'm on it now, I haven't  found consistent 4g service and will likely put it up 30 feet or so and would like to rig up a battery charger. Should I dump the lithium entirely and use NiCad or lead acid? My choice would be nimh not sure how they handle cold, but can be run with out a charge controller dissipating extra energy as heat. (discovered this long ago, think I posted a link here at some point.)
Any ideas? I have many small 6 volt nominal 4-5 watt solar panels or could run electric up to it from home.
  • Estragon
    You're putting the hotspot up 30'?  Does it have an antenna port?  If so, I'd put an external antenna up higher.  If not, maybe a vehicle type booster.
    AFAIK, lithium has to be heated to > ~0°C to charge.  My hotspot knows the internal battery temp and won't charge cold.
    Nice to know, perhaps that is what I was running into yesterday. I set in car with a power bank attached. it appeared to charge during the day but quit charging after sunset, only got down to 33-34 when I brought it in and charged.
    No antenna port, it's a 'Jetpack' my brother had bought for my mom's trip years ago.
  • wellbuilt
    wellbuilt Solar Expert Posts: 763 ✭✭✭✭
    I’ve been using this for a year  and it takes me from lol most no G to 4 Gs for 89 bucks off eBay .
     This one is for att service but the sell different units , my buddy has one that will do version att
      Last week I ran the wire up 22’ and mounted it on the house then dropped down the wall into the kitchen .
       In a moment of excitement I drop the little block box and broke the antenna 🤯.
      The unit in the pic is a replacement .
       Disregard the poor reviews on Amazon this thing works great .
      I would bet the people making the poor reviews are not snugging the antenna connections with a wrench .
      I used this unit sitting on a 5 gallon bucket for a few weeks before I hung it up .
      It uses a few watts of power .
      The only down fall is the connections are a little Fragile
  • Estragon
  • Estragon
    I'm not sure if mine does it or not, but the hotspot may throttle charge rate down as temp approaches 32F.  I know mine stop lower than that, but can't tell if it starts throttling the rate at (say) 45F.  Some power packs need a minimum draw to wake and/or power the output, so it's possible the hotspot throttled to below the min pack amp draw in the cool/cold?
