I guess it is Official... Northern California cannot keep the utility power on in sunny/warm weather
@Westbranch OK if I misunderstood.too. No problem.
A couple days ago I saw a lead in on the NEWS that the power was going to be cut again... nothing after that ,so was it a false alarm or ??? I hope it did not occur.
120,000 lost power up near the wine country. Average about 24 hours of lights out. Storm coming this wednesday and more outages. This is the new normal BTW."we go where power lines don't" Sierra Nevada mountain area
Thanks Dave. Whipping up the fires again or are they mostly contained??Oh NO! not the wineries! The Plebeians will have to drink water now.
The upcoming storm is going to be cold and wet. rain and ice. Not enough wind to trigger the safety shutdowns - I hope.But the latest meme - When do you start to defrost the turkey ? Don't worry, pg&e is going to do it for you !Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
They won't defrost you Mike, or us
A total PITA to be in business in the wine country. Losing millions per day!"we go where power lines don't" Sierra Nevada mountain area
