Longevity of AGM vs LiFePo4 in high temperature environments
magicbus
magicbus Registered Users Posts: 10 ✭✭
Just to be clear, my specific application is RV / mobile, but the question is applicable to fixed-site installs as well. I'm trying to decide between AGM & LiFePo4. I'd frankly rather go w/ AGM, despite the weight/size disadvantages, as I'm much more familiar with them. But I have one major concern: The heat. We're in Phoenix, and the batteries will be located in an unconditioned metal shell (a bus). This last summer I read 134 inside at the peak of the day. Granted, this won't be every day. Especially not when we're on the road. But more days than not, the temps will be what most batteries would consider hostile. I'm fairly certain LifePo4 would be better in this regard. What I don't know is how much better. Given the extra complications & up-front price, would LFP be a net win for my environment? I don't want to spend $2500 or more on an AGM bank that dies in 3 years. But I also don't want to spend 3 times that on an LFP bank that dies in 5. What would you do?
  • Estragon
    Estragon Registered Users Posts: 4,500 ✭✭✭✭✭
    LiFePo aren't going to like really high heat either.
    While not specific to this chemistry, this gets into some detail:
    https://batteryuniversity.com/index.php/learn/article/bu_808b_what_causes_li_ion_to_die
    Summarizing; a fully charged lithium battery in high heat can degrade fairly quickly.
  • Marc Kurth
    Marc Kurth Solar Expert Posts: 1,187 ✭✭✭✭
    edited November 2019 #3
    I cannot give you real life experience with LiFPo4, but I can tell you about thousands of AGM batteries - using high quality models.
    A motor coach or tour bus running the Phoenix, Palm Springs, Las Vegas highways will generally get 5 years of service life. Using temperature recorders, we measured 140F-155F battery temps regularly, in this application.YES, heat dramatically reduces AGM battery life! The identical application in Northern climates are on a 7-9 year replacement cycle.
    Cooler is better, but speak with your battery supplier about the specifics of your application. If they do not tell you to expect a 50%-70% reduction in lifespan, they do not understand what you are asking.
    Extreme cold is actually good for AGM battery lifespan, but you will see a reduction in capacity as the battery temperature falls. Good AGM's do not freeze until they hit -90F to -95F when fully charged, and it's a curve down toward zero charge level. Quality AGM's have around 90% capacity at 20F, dropping to 55% capacity at 50% state of charge and about 35% at -40F. (We do a lot Arctic applications)
    Sure, I have read blogs and supplier literature on LiFPo4, but I have ZERO actual field experience for an RV. Anyone can quote Google, so I suggest speaking with people who have dealt with your application.
    Remember that like most things, all AGM's are not created equal. Work with a manufacturer who publishes the kind of data talked about above.
    Marc
  • magicbus
    That's very useful, Marc. Thank you so much!
    For what it's worth, I'm thinking Lifeline AGMs. If I could get 5 years w/ them in my climate I'd be happy. I'd be paying at the very least double that for LPF, which I'd be suspect of lasting 10.
  • Marc Kurth
    magicbus, If you can get twice the life, at twice the cost - you are even - depending on the value of your invested capital. If you go Lifeline, we should talk about charging because their requirements are different that everyone else. (I don't sell chargers, I am an application specialist)
    Marc
  • mcgivor
    edited November 2019 #6
    Having observed the effects of high temperature on both FLA and LFP, the FLA would increase in temperate over time due to inability to cool sufficiently overnight due to la tent heat. When maximum ambient was 40°C for overy a week the FLA temperature would  increase to~50°C, the LFP on the other hand remained below ambient usually by ~5°C.
    AGM are more efficient than FLA so self heating would probably be less, another facor could be the FLA were monoblock GC batteries, the LFP are single cells which results in greater surface area for overnight cooling. With LFP the BMS should provide high temperature protection, the BMS I use disconnects the battery at 70°C.
  • Marc Kurth
    Yep, but remember that In Phoenix and the rest of the valley, 40C at midnight is not unusual after the "summer heat switch" gets activated! Batteries sitting in a metal box called an RV, at 120+F ambient creates some interesting challenges. The add the reflected heat from the asphalt.
    My approach would be to investigate what happens to LiFPo when charging and discharging at 120F to 140F, Then repeat the process at low temperature.
    Again, I have zero field experience with LFP- the current generation may be fine at extreme temperatures!
    Marc
  • mcgivor
    Marc
    The effects would be different without overnight cooling, my observations were where the minimum temperature is close to 30°C, usually after midnight in a room in free air, not a s box. The primary reason I changed to LFP was temperature and I'm very pleased with the results, all other benefits are welcome additions.
  • Marc Kurth
    Sounds like high temps are not a problem. That's good to know!
    Marc
    And since you are in an RV--Are you going to hit seriously cold areas? Will the battery bank be "insulated/ventilated box"?
    Li Ion batteries generally do not like to operate below freezing (or as low as 25F). If your bus gets cold soaked in a mountain/far north region, an insulated or even heated battery box could be required.
    As Marc says above, AGMs (and any FLA battery) is a better choice for cold.
  • magicbus
    Great info, folks! Sure do appreciate the input.
    Below freezing? Nope. The wife has already told me we're not going anywhere cold!  :)
    Seriously though, the box will be inside the vehicle. It's not the times we're traveling - where the space will be heated or cooled as required - that I'm concerned with. It's more the months it's parked at home I'm worried about.
  • mcgivor
    Remove the batteries when parked, they will need to be charged periodically especially LA, LFP have extremely low self discharge.
  • magicbus
    I had considered doing that, mcgivor. And I haven't stopped considering it. But disconnecting/reconnecting, and moving 120# batteries in & out of a short bus every time it's parked for a week is going to be a real pain. Enough of a pain that I doubt I'll keep it up for long. If I was just parked for the summer it wouldn't be a problem. But our trips will be more frequent, short get-aways than seasonal expeditions. The irony is with LFP it wouldn't be nearly as much of a hassle.
