solar powered stock tank heater
kandebeach
Registered Users, Users Awaiting Email Confirmation Posts: 1 ✭
I have a 600 gallon tire stock tank. I have no access to electricity. What do I use to keep it from freezing?
Propane heaterIsland cottage solar system with approximately 2300 watts of panels, 1kw facing southeast 1.3kw facing southwest. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 32nd year.
We have had that question a few times over the years here... And, I don't think we ever had any good answers.
In winter, when there is just not a lot of sun, there is very little energy/heat available from the sun (worse the farther north you go).
http://www.solarelectricityhandbook.com/solar-irradiance.htmlGreat Falls
Measured in kWh/m2/day onto a solar panel set at a 27° angle from vertical:
(Optimal winter settings)
Lets say you decide to use a 1,000 Watt stock tank heater:Jan Feb Mar Apr May Jun 2.31
3.40
4.06
4.44
4.50
4.60
Jul Aug Sep Oct Nov Dec 5.08
5.01
4.61
3.69
2.67
2.14
http://stockyardsupply.com/index.php/watering-systems/stock-tank-de-icers-heaters/
Assume it is a 120 VAC 1,000 Watt heater and you want to use solar panels. Use 250 Watt @ Vmp~30 Volts, and 4 of those in series... Don't bother with batteries. They will be expensive and prone to failure. Just dump the heat into the tank and use the water itself for your energy storage.- 1,000 Watts * 2.14 hours of sun * 0.77 derating for panels = 1,648 Watt*Hours per December day (really less because solar panels+sun+electrical IV curve from panels is not 100% panel->sun without using other stuff)
- 1,648 Watt*Hours => 5,623 BTU https://www.inchcalculator.com/convert/watt-hour-to-british-thermal-unit/
- 5,623 BTU per day / 91,500 BTU per Gallon (roughly) = 0.06 gallons of propane per day
- 20 gallon tank (roughly 80 lbs) / 0.06 gallon per day = 333 Days of "solar equivalent heat" (10 years of December)
- 12,470 BTU per hour => 3,655 Watt*Hours per hour or ~3,655 Watt heater equivalent
- 12,470 BTU per hour / 91,500 BTU per gallon = 0.14 gallons of propane per hour
- 20 gallon (100 lb tank) / 0.14 gallons per hour = 144 hours of heating
If you can guess at how much ice per day is created in the tank, could work backwards from that. Say 20 lbs of ice per (bad) December day/24 hours:- 20 lbs of water to ice * 144 BTU per lb of water/ice (latent heat of fusion) = 2,880 BTU per day
- 2,880 BTU per day of "anti icing" heat * 1/91.500 BTU per gallon (propane) * 1/0.50 efficiency (guess) = 0.06 gallons of propane per day
- 20 gallon tank propane (100 lbs) / 0.06 gallons of propane per 20 lbs of ice per day = 333 days of heating per 20 gallon propane tank (guessing at 20 lbs of ice per day)
Other than insulated tanks, under ground piping, etc... I am not sure what else to do/say:
https://duckduckgo.com/?q=insulated+stock+tank
I also guess you are trucking water or have a Wind powered water pump on site? No power? If wind pumping, can you simply let the wind pump overfill the tank during winter with "warm well water" to reduce/prevent icing?
Where are you? How cold is cold?
Tony -
Is the tank already black? If not, could it be painted?
Those KWH per day numbers are not valid for a direct connection from solar panel to a heating element. Current id proportional to light intensity. Given that 50% current could be common, the result is 1/4 of the wattage and it gets much worse the lower you go. You need an electronic module that matches the panels output to the heater element.
