solar powered stock tank heater
kandebeach
kandebeach Registered Users, Users Awaiting Email Confirmation Posts: 1
I have a 600 gallon tire stock tank.  I have no access to electricity.  What do I use to keep it from freezing?
  • 706jim
    706jim Solar Expert Posts: 529 ✭✭✭✭
    Propane heater
    Island cottage solar system with approximately 2300 watts of panels, 1kw facing southeast 1.3kw facing southwest. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 32nd year.
    We have had that question a few times over the years here... And, I don't think we ever had any good answers.
    In winter, when there is just not a lot of sun, there is very little energy/heat available from the sun (worse the farther north you go).
    Great Falls
    Measured in kWh/m2/day onto a solar panel set at a 27° angle from vertical:
    (Optimal winter settings)
    JanFebMarAprMayJun
    2.31
    3.40
    4.06
    4.44
    4.50
    4.60
    JulAugSepOctNovDec
    5.08
    5.01
    4.61
    3.69
    2.67
    2.14
    Lets say you decide to use a 1,000 Watt stock tank heater:
    http://stockyardsupply.com/index.php/watering-systems/stock-tank-de-icers-heaters/
    Assume it is a 120 VAC 1,000 Watt heater and you want to use solar panels. Use 250 Watt @ Vmp~30 Volts, and 4 of those in series... Don't bother with batteries. They will be expensive and prone to failure. Just dump the heat into the tank and use the water itself for your energy storage.
    Guess that a propane heater is something like 50% efficient, that would be:
    • 5,623 BTU per day / 91,500 BTU per Gallon (roughly) = 0.06 gallons of propane per day
    • 20 gallon tank (roughly 80 lbs) / 0.06 gallon per day = 333 Days of "solar equivalent heat" (10 years of December)
    Very little heat from 1,000 Watts of solar panels (ideally) connected to a 1,000 Watt solar heater... In the stock heater link above, they have a 12,470 BTU per Hour propane heater:
    • 12,470 BTU per hour => 3,655 Watt*Hours per hour or ~3,655 Watt heater equivalent
    • 12,470 BTU per hour / 91,500 BTU per gallon = 0.14 gallons of propane per hour
    • 20 gallon (100 lb tank) / 0.14 gallons per hour = 144 hours of heating
    How many hours of propane heating per day do you need? I don't even really have a guess. Size of tank, insulated or not, make up water per day or per week, temperature of makeup water, wind chill, exposure of tank to wind, etc.
    If you can guess at how much ice per day is created in the tank, could work backwards from that. Say 20 lbs of ice per (bad) December day/24 hours:
    • 20 lbs of water to ice * 144 BTU per lb of water/ice (latent heat of fusion) = 2,880 BTU per day
    So, just guessing here with the 20 lbs of ice per day, but 1,000 Watts of solar panels may be able to prevent 20+ lbs of ice per day (very roughly 5,623 BTU per December day). And propane:
    • 2,880 BTU per day of "anti icing" heat * 1/91.500 BTU per gallon (propane) * 1/0.50 efficiency (guess) = 0.06 gallons of propane per day
    • 20 gallon tank propane (100 lbs) / 0.06 gallons of propane per 20 lbs of ice per day = 333 days of heating per 20 gallon propane tank (guessing at 20 lbs of ice per day)
    Anyways, just some very quick math and, at least an idea, of how to figure how much heat per day if you can estimate/weight the amount of ice that that forms over 24 hours in your stock tanks. And for a "safety factor", I would use at least 2x (two times more energy estimated because of the very fuzzy guesses above).
    Other than insulated tanks, under ground piping, etc... I am not sure what else to do/say:
    https://duckduckgo.com/?q=insulated+stock+tank
    I also guess you are trucking water or have a Wind powered water pump on site? No power? If wind pumping, can you simply let the wind pump overfill the tank during winter with "warm well water" to reduce/prevent icing?
  • icarus
    Where are you?  How cold is cold?
  • fratermus
    fratermus Registered Users Posts: 48 ✭✭
    Is the tank already black?  If not, could it be painted?
  • NANOcontrol
    NANOcontrol Registered Users Posts: 288 ✭✭✭
    Those KWH per day numbers are not valid for a direct connection from solar panel to a heating element.  Current id proportional to light intensity.  Given that 50% current could be common, the result is 1/4 of the wattage and it gets much worse the lower you go. You need an electronic module that matches the panels output to the heater element.
