Battery Temp sensor question
I’m guessing not. I tried the same thing between Xantrex and Magnum to no avail. Give a quick call to Midnight tech support and they should be able to answer the basic topology of their sensor, and whether or not it may b compatible.
Tony -
Thanks, calling will be my next step after some more comments roll in.icarus said:I’m guessing not. I tried the same thing between Xantrex and Magnum to no avail. Give a quick call to Midnight tech support and they should be able to answer the basic topology of their sensor, and whether or not it may b compatible.
Littleharbor2,
IIRC, it has been said, that the Trace/Xantrex BTSes are not interchangeable.
Believe, that the Outback and MidNite BTSes ARE interchangeable, if that would be of any use to you.
FWIW, VIcOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum. -
Thanks Vic. Reason I'm asking is a friend recently bought a Classic 150 and I don't think it came with a BTS. I didn't see one in the box anyway. I have a bunch of the Trace sensors and hoped she could use one of them. I just bought a Midnite version at auction for 14.50 today. Glad it wasn't a wasted purchase.
I can't comment on those two brands, but for future searchers, will advise on Morningstar ones.
They're based on simple thermistors, as I suspect they all are (cheap, reliable, accurate enough). Based on the temperature reported at various resistances, Morningstar uses a 10K @25C one, with beta ~3900 (+- 100 should be fine), and alpha ~-4.4 (less important). Suitable ones would be US Sensor PT103J2 or AC103J2F, Ametherm ACC-104, or Littlefuse AC103J2F.
If the controller shows the battery temp, it's not too hard to figure out, simply taking a few data points using a 50K potentiometer.
If you have two to compare, measure the resistances at room temp, stuck in a glass of ice water, and in a glass of warm water. If the resistances match within 5-10%, close enough (they'll be within a couple of degrees C). -
The MidNite and Outback are both 10K nominal at 25 C, NTC. Had found a very standard TDK unit that is readily available. Also, about 18 months ago there were several discussions on BTS selection, in the context of making a BTS for a cell cap of a forklift battery.
allelectronics.com has had the proper sensor as a normal-stock item ... am running out of sunlight here, so will not search for either this, or the previous discussion on HB BTS..
Good that you found a MN BTS at a reasonable price, littleharbor.
It is possible that MN ceased including BTSes with Classics, because, when several Classics are in Follow Me, only BTS is needed.
FWIW, VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum. -
Hi Vic,
Classic for solar only does not include BTS, you have to buy it separately.
A+,
Erik
A ha, It is a Classic SL model. Thanks Eric. Thanks all for all your input.SolarMusher said:Hi Vic,
A+,
Erik
Mike
OK, Thanks Erik & Mike, did not know that detail. VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum.
- 234 Forum & Website
