Battery Temp sensor question
littleharbor2
littleharbor2 Solar Expert Posts: 2,123 ✭✭✭✭✭
Does anybody know if a Trace Xantrex BTS is interchangeable with a Midnite solar BTS?
  • icarus
    I’m guessing not.  I tried the same thing between Xantrex and Magnum to no avail.  Give a quick call to Midnight tech support and they should be able to answer the basic topology of their sensor, and whether or not it may b compatible.
  • littleharbor2
    Thanks, calling will be my next step after some more comments roll in.
  • Vic
    Littleharbor2,
    IIRC,  it has been said,  that  the Trace/Xantrex BTSes are not interchangeable.
    Believe,  that the Outback and MidNite BTSes ARE interchangeable,  if that would be of any use to you.
    FWIW,   VIc
  • littleharbor2
    Thanks Vic. Reason I'm asking is a friend recently bought a Classic 150 and I don't think it came with a BTS. I didn't see one in the box anyway. I have a bunch of the Trace sensors and hoped she could use one of them. I just bought a Midnite version at auction for 14.50 today. Glad it wasn't a wasted purchase.
  • mike_s
    mike_s Registered Users Posts: 162 ✭✭✭
    edited November 2019 #6
    I can't comment on those two brands, but for future searchers, will advise on Morningstar ones.
    They're based on simple thermistors, as I suspect they all are (cheap, reliable, accurate enough). Based on the temperature reported at various resistances, Morningstar uses a 10K @25C one, with beta ~3900 (+- 100 should be fine), and alpha ~-4.4 (less important). Suitable ones would be US Sensor PT103J2 or AC103J2F, Ametherm ACC-104, or Littlefuse AC103J2F.
    If the controller shows the battery temp, it's not too hard to figure out, simply taking a few data points using a 50K potentiometer.
    If you have two to compare, measure the resistances at room temp, stuck in a glass of ice water, and in a glass of warm water. If the resistances match within 5-10%, close enough (they'll be within a couple of degrees C).
  • Vic
    The  MidNite and Outback are both 10K nominal at 25 C,  NTC.  Had found  a very standard  TDK unit that is readily available.   Also,  about 18 months ago there were several discussions on  BTS selection,  in the context of making a BTS for a cell cap of a forklift battery.
    allelectronics.com has had the proper sensor as a normal-stock item   ...   am running out of sunlight here,  so will not search for either this,  or the previous discussion on HB BTS..
    Good that you found a MN BTS at a reasonable price,  littleharbor.
    It is possible that MN ceased including BTSes with Classics,   because,  when several Classics are in Follow Me,   only BTS is needed.
    FWIW,    Vic
  • SolarMusher
    SolarMusher Solar Expert Posts: 176 ✭✭✭
    Hi Vic,
    Classic for solar only does not include BTS, you have to buy it separately.
    A+,
    Erik
  • littleharbor2
    Hi Vic,
    A+,
    Erik
    A ha, It is a Classic SL model. Thanks Eric. Thanks all for all your input.
     Mike
  • Vic
    OK,  Thanks Erik & Mike,   did not know that detail.     Vic
