Diablo weather and booms in the night...
softdown
Solar Expert Posts: 4,078 ✭✭✭✭
You will never achieve "I've seen it all" status. Thought I must be getting close then this happened. Heard a boom around 1am and the whole building shook a bit. Even got up to check if the garage was still standing. Thought maybe I lost a couple panels. Couldn't sleep for quite awhile.
What happened? Previous high winds had carried a very old and dilapidated 700 gallon water container over the fence. I couldn't lift it back over the fence without destroying the thin electrical wire. Its advanced age had rendered it useless.
It was still good for something. Last nights sustained winds of 40, with gusts over 50, picked it up and slammed it against this building. The building literally shook a bit. Created a solid boom in the noise department. Even the dogs look startled and concerned.
Ever carry a sheet of plywood in heavy winds? Gives you an idea how much energy can be delivered to an area with a significant surface area. I'd quickly estimate that wind born 700 gallon container delivered the force of several hundred hammer blows.
No apparent damage other than a water container in multiple pieces. I might post pics when the weather settles back down. Today looks nasty with the sun making a scheduled brief appearance at 6pm. An ~ hour of very late afternoon sun if lucky. Winter cometh.
If my really simplified arithmetic is right, a sheet of plywood in 50mph wind would get ~200lbs of wind force. Wind is definitely a force to be respected!Off-grid.
A church construction worker was killed when the wind slammed the door on him. I'd guess your number might be low and I have no background in these measurements. I'd guess this thing delivered a couple thousand pounds of force for a millisecond. I think it held at least 700 gallons in its day. An adult could squeeze through that hole.Estragon said:If my really simplified arithmetic is right, a sheet of plywood in 50mph wind would get ~200lbs of wind force. Wind is definitely a force to be respected!
there is a powerful front line coming down the west coast today and tomorrow, they project winds up to 50 MPH across the coast and inland plus a lot of rain for us, watch your forecasts...
Dangerous thing about the wind is the gusts. Like waves, it is the extremes that often represent the greatest danger:
1) 10' waves may be fine but what about that 20' rogue wave?
2) 50 mph winds may be fine but what about that 85 mph gust?First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
Keep in mind that's 200lbs pressure over the 32sq.ft. sheet. Once moving there's momentum (force = mass x acceleration), and in a strike the force would be concentrated on a much smaller area (like the back of your head).Off-grid.
- 230 Forum & Website
