3 pannels in parallel
cory
Registered Users Posts: 1 ✭
I have three panels with 18v each in parallel which originally gave 18v but know the controller is saying 23.9v and only 6 amp can anyone tell me what's going on?
Sounds like you have changed your method of measuring the voltage. Perhaps you were using a charge controller to measure the voltage the solar panels were creating while charging, and you later measured the voltage with a multimeter, which would be open circuit voltage without a load.
This would correspond with VMP and VOC, such as this label;
As far as your (apparently) low current, this could be due to your batteries approaching a full state of charge.
cory said:I have three panels with 18v each in parallel which originally gave 18v but know the controller is saying 23.9v and only 6 amp can anyone tell me what's going on?
a) way too high for a 12 volt battery bank ?
b) way too low for a 24 volt battery bank ?
We need more details ...
Can you tell me what is going on? What is the controller telling you that 23.9V is, panel or battery? 18V sounds like panels optimum power point voltage. 23.9 sounds like open circuit voltage for panel. Sounds a little high if 6A is flowing anywhere. Is that in or out of controller?
mvas said:cory said:I have three panels with 18v each in parallel which originally gave 18v but know the controller is saying 23.9v and only 6 amp can anyone tell me what's going on?
>>SNIP<<
Here's the data from a 175 watt, 12 volt panel. Are your panels this size, power wise?
Electrical Data
Maximum Power Output:
175 Watts
Max Operating Voltage (Vmp):
18.95 Volts
Max Operating Current (Imp):
9.50Amps
Open Circuit Voltage (Voc):
23.90 Volts
Short Circuit Current (Isc):
9.87 Amps
Module Efficiency:
17.0%
Lot bigger panels than I expected. Everything sounds like it is doing just what it is supposed to do.
- 230 Forum & Website
