black poly pipe
ws9876
Solar Expert Posts: 453 ✭✭✭
is your regular 1 inch dia black poly water pipe electrically inert or does it conduct.? Scrap pieces are handy to make into isolation
mounts for wires..
The black poly, or ABS is a dielectric, meaning it doesn't conduct electricity.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
