Inverters 2019
ws9876
Solar Expert Posts: 453 ✭✭✭
Anyone know if there are some of these cheaper inverters 2-3K watts that are pretty good? Its been long enough now that maybe
some of the imports are getting better in quality...no? Ebay has the Renogy, Samlux, and many others..A few years ago I wouldnt have even considered these types but ...eventually they are going to get better as components get cheaper..sine wave only
this one looks interesting for the money..not an Outback but much cheaper..
Cotek are a good mid range inverters as are Samlex, who sometimes uses Cotek in their product lineup.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
If you don't need an AC/DC charger, the Cotek might be a decent choice. An Outback would have a charger and transfer switch, which may or may not be important.Off-grid.
btw, can the Outback 24v chunk grid tie AND charge batteries automatically?
