Planning a new RV Solar install, possible options and looking for opinions.
DakotaJim
Registered Users Posts: 8 ✭✭
I have some parts to install on a new 5th Wheel and trying to decide what is a better layout. The parts I have as per my tag, I also have a Tristar MPPT 60A controller (will probably not use this, because I want to shift to an entirely Victron based system and have everything bluetooth to my phone), but I want to add an additional portable ground mount PV for when the rig is parked in the shade (could possibly put it on the roof, there is clearance).
I had the 3 Kyoceras in parallel in an old system (individually fused on the positive legs, because I had ports to add the 4th PV panel, just never got one), it worked well, filling up 4 Vmaxtanks 125Ah AGM's in 24V system for the last 2 years, I could even run the RV's AC for a few hours at a time. But now I will probably go Lithium (that is another question, but thinking TESLA modules, Battleborn, or alibaba prismatics) in at least 1000Ah, thinking 2 of the TESLA's for more bang for my buck, but I may have to come up with a cooling solution.
Thinking of the 24V versions, but not sure what specific Victron Charge Controller and Inverter/Chargers I should get to cover the possible 4th panel (or which panel should I look for, do I need to match Vmp and Imp exactly?). I will probably use the Trimetric 2030-RV as a secondary SoC and get the Victron 712 Battery monitor, unless I can get enough selling it locally when I list the Tristar.
Any obvious things I'm missing or should plan for?
3 Kyocera KU340-8BCA, Victron MPPT 150/100 Tr, Victron 712 with temp sense, 4 EnjoyBot 100Ah Lithium batteries,
Victron 12V 3000W Multi inverter, Cerbo GX using a AT&T Mobly for internet.
The most obvious thing missing to me is loads. What are you wanting to run, and for how long?Off-grid.
Critical load is a 24V CPAP that has a humidifier, being able to run that in addition to the propane furnace in the winter or the 13.5K RV AC in the summer is what I'm planning for.3 Kyocera KU340-8BCA, Victron MPPT 150/100 Tr, Victron 712 with temp sense, 4 EnjoyBot 100Ah Lithium batteries,Victron 12V 3000W Multi inverter, Cerbo GX using a AT&T Mobly for internet.
It would help to quantify the loads. What is the current draw ('X' amps at 24v) of the CPAP. Likewise for the furnace fan and AC.
4 x 340w panels (in full sun and properly tilted) may produce ~1000 watts. Depending on location and season, ~ 4-5kwh/day. A 4th panel doesn't need to match exactly, but should be "close" (eg within 10%).Off-grid.
Thanks, I don't have any numbers for the furnace or AC, but the CPAP transformers are 3.75A (both 115V and 12V), I'm assuming that is the maximum; but they are pretty big, much larger than a standard wall wart, but with the heated hose and the humidifier running, it may be more. I'll run the CPAP on a power meter and see what it says.
3 Kyocera KU340-8BCA, Victron MPPT 150/100 Tr, Victron 712 with temp sense, 4 EnjoyBot 100Ah Lithium batteries,Victron 12V 3000W Multi inverter, Cerbo GX using a AT&T Mobly for internet. -
After finally installing the Multi, I ran the CPAP and discovered it actually runs at 6 amps using the 115V transformer. I have also found that the 12V to 24V transformer could not run the CPAP in the RV from the 12v batteries, the CPAP would just shut down.
DJ,
Just ot be clear, was that 6 amps @ 115 VAC input (690 Watts), or 6 amps at 12 VDC (72 Watts) (really a DC to AC inverter, not a transformer?). Or 6 amps at some other working voltage?
690 Watts is a lot of power for a small or even medium sized solar power system (690 Watts * 8 hours = 5,520 Watt*Hours of energy).
- 654 Solar Water Pumping
