Battery service overdue
mcgivor
Solar Expert Posts: 3,854 ✭✭✭✭✭✭
Strange discovery with my Morningstar controller, seems like I'm overdue for battery service by almost 43 billion days, or 11, 770 years, these batteries must be durable.
LOL. I'm a bit surprised it can count that high, though it looks like it's "only" ~4.3 billion days.
Assuming 32 bit processor, max int would be 2^32=4,294,967,296 ...so you better get busy
You may be correct, phew it's only been around thousand years, that makes me feel better
mcgivor, I want a set of THOSE batteries.
