Small electric hot water heater
![wellbuilt](https://we.vanillicon.com/e15986feefd0061c1d5ae2f89c628abe_100.png)
wellbuilt
Solar Expert Posts: 763 ✭✭✭✭
Hi all , my question for the board is , is it possible to just plug in a 20 gallon electric water heater .
The heater has a 1500 watt element .
I was thinking this would be fast and easy for some temporary hot water for showers .
I have a 3600 watt out back inverter and 4200 watts of solar with a 415 ah battery bank that is drawn down to 85 /90% full at night .
I have a lot of power going to wast this time of year .
I just need a little more time to get my Permanent radiant heat floor hot water system working
In October / November I turn off the water befor is freezes .
Out back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar .
It shouldn't be a problem, I'd just run it on a timer from say 1-4 in the afternoon. Then there is no risk of it drawing down your system over night. Check the recovery on the water heater to see what they expect it to take to fully heat, I can't recall the parameters, likely they are not regulated.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Thanks photowhit I figured it would be ok , do you think I would be better off running it from solar panels directly with out inverter or
CCOut back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar . -
No, If you have a large enough inverter, I'd just run it off AC it'll use a tad more electric, but I have struggled with trying to be comfortable with a DC design, but high voltage DC doesn't work well with the thermostat, so you would have to have a relay to run the DC electric that would shut it off from a thermostat run off AC.
I run a 3600 volt 240 volt element on 120 volts. It runs at 1/4 the wattage or 900 watts. Takes quite a while in a 30 gallon tank.
Did you pick the heating element deliberately or did you just buy the water heater and make it work ?
Or did you want to stay at 900 watts ?Out back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar . -
It depends on your array voltage and the water heater. I have a 6 gallon ECOsmart with a 120V 1500W element. That is a good match for 60 so volts. You can't change this heating element. Another tank has a 120V 2000W element. screw in and these are common elements that could replace 240V ones. I use a circuit that keeps the panels above the power point voltage. That allows me to operate the heater in parallel with a charge controller without going thru the batteries. It will send as little as 5W to the heater to more than 500W the entire day. A 5500W 240V element is 10.5 ohms. With your number of panels, a direct connect wouldn't be that bad using a timer. A fixed resistance load really drags down a panels voltage in less than prime sun. I'm low usage and I have all the hot water I need with only about 2700WH a day. My system works similar to this.
wellbuilt said:Did you pick the heating element deliberately or did you just buy the water heater and make it work ?
Seems to me at least some 20 gal tanks run on 120v out of the box. Depending on inlet water temp and set temp, I think 1500w would take ~2hrs to reheat 20 gals.Off-grid.
Yes the water heater is 120 volt , that is what I was thinking 2 hrs should fine .Out back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar .
Nice vid nano , I my try that in the FutureOut back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar .
- 425 Caravan, Recreational Vehicle, and Marine Power Systems
- 651 Solar Water Pumping
- 611 Discussion Forums/Café
