Looking for assistance with Grid Support settings on Schneider XW6848+
Thank you.
I will see if they came out w/something newer than 01.07.01 bn0003
the XW6848 is on bn0004 which is what I'm on, not sure about the XW6048
DickyDck said:Coming back to this, now have 16 batteries, 2 strings of 8, 48v each string. Set Inverter and Controllers to 440ah. Today is a semi sunny day, some roaming clouds occasionally blocking my array. Been kinda sitting here watching the paint dry and what I have noticed as cursory results...
1. THe situation only happens usually when I'm above 4500w generation, but did happen when under. It has been sitting in the 4k range for a while and has not dropped like it used to.
2. Still drops to 0 when clouds roll in and darken the sky heavily, then after a few seconds it climbs back up to 1k-3k for overcast power production, and will climb back up when the clouds fly past. So anytime there is a drastic drop in sunlight the issue still seems to occur.
3. The batteries don't seem to switch from charge/discharge as fast as I noticed before.
Of course this is less than 24 hours worth of results, but it seems adding another string has done "something" good. It is nice to see power generation above 4k steady without total kill drops. I'll give it a few days and see what happens. BTW I did a master reset to Factory after adding the batteries and setting all the parameters again.
While it doing that it pass the power from the grid to your load instead from the PV. the charge controllers will have no load and pumping all the power from the PV to your battery banks. In your case the 24 320watts Panel will give you from 100 to 155 amps depend on the condition of the sky and the voltage of your battery.
how do you prevent your AGM battery from get damage from all those large amperes pumping to them for 5 minutes? I ask because I have the same problem. Mine battery bank are FLA 370 amperes. should be charged at 35 to 50 amps Max. but sometime I see 80 to 100 amps pumping to it.
Your case is better than mine. at least you can pump 20@ charge current to the AGM, that is about 88 amps, but 150 amps would be still a problem if it does very often.
Best wishes
XW6848+ Magnum 4448PAE (Backup) 7800 watts total mixed Panels, 370 AH @48volts battery bank. Grid assist and soon be Tied. -
paulcheung said:DickyDck said:Coming back to this, now have 16 batteries, 2 strings of 8, 48v each string. Set Inverter and Controllers to 440ah. Today is a semi sunny day, some roaming clouds occasionally blocking my array. Been kinda sitting here watching the paint dry and what I have noticed as cursory results...
Best wishes -
The XW6048 never got firmware to limit current in bulk only. XW+ and XW pro can. Take a look below. I and a few others are trying to get Schneider to add this to the mppt firmware. If this is something you want you need to fill out the request and tell them.
Dave Angelini said:The XW6048 never got firmware to limit current in bulk only. XW+ and XW pro can. Take a look below. I and a few others are trying to get Schneider to add this to the mppt firmware. If this is something you want you need to fill out the request and tell them.
XW6048 is not supported for 10 years now because of many reasons including memory limitations, parts, and topology.
Or you could say they do this to make people realize if they depend on this equipment, they need to be responsible."we go where power lines don't" Sierra Nevada mountain area
So it is EOL then, but... they still sell it or are the ones I see from all the companies old stock?
Dave Angelini said:The XW6048 never got firmware to limit current in bulk only. XW+ and XW pro can. Take a look below. I and a few others are trying to get Schneider to add this to the mppt firmware. If this is something you want you need to fill out the request and tell them.XW6848+ Magnum 4448PAE (Backup) 7800 watts total mixed Panels, 370 AH @48volts battery bank. Grid assist and soon be Tied.
DickyDck said:So it is EOL then, but... they still sell it or are the ones I see from all the companies old stock?
5 years ago the the 5 year warranty ran out on XW6048 and if you buy one, it is not supported by Schneider Electric. There probably is some support for very large installations but I am guessing on that one.
There is support from the secondary repair market but that changes as these folks go in and out of business.
I do not understand the previous post. Mixing makes of equipment is very hard to do grid tied."we go where power lines don't" Sierra Nevada mountain area
I'm sorry, I got Paul and bsair mixed up. Bsair is on the 6048, Paul is on the 6848.
DickyDck said:XW6848+ Magnum 4448PAE (Backup) 7800 watts total mixed Panels, 370 AH @48volts battery bank. Grid assist and soon be Tied.
Yeah, I am not sure I can help since mine doesn't ever error out and start the count down. If you are getting AI frequency errors, I think you might have an issue with the grid coming in? I think default frequency low is 55 and high is 65, if you are getting errors and countdowns that must mean you are outside of that range. I didn't see you list it out in your earlier post, but what kind of charge controller do you have? -
I have 2 Outback FlexMax 60 and 80.XW6848+ Magnum 4448PAE (Backup) 7800 watts total mixed Panels, 370 AH @48volts battery bank. Grid assist and soon be Tied.
paulcheung said:I have 2 Outback FlexMax 60 and 80.
- 228 Forum & Website
- 618 Discussion Forums/Café
