What is the best way to utilize these solar parts I currently have and any advice on buying more ite
fisherus
Registered Users Posts: 3 ✭
Currently I have 8 100W 12V Renology panels, Epever MPPT Solar charge controller 12V/24V Solar Regulator 150V 40A/30A/20A/10A +40A+Meter&cable, 2000W Pure Sine Wave Inverter, 100A Digital Voltage Power Energy Meter Multimeter w/100A fuse, Anjoshi 50A-300A fuse holder, Drok DC Battery Capacity Voltage Temp monitor, udell 24VDC/13.8V converter, Battery disconnect switch, 2ga, 8ga, 10ga wire. 4 12V 110A flooded mat batteries.
I need to know how to set up 24V System and can I charge more batteries with this amount of panels?
What are you trying to do?Off-grid.
