Clipping
Hey all. Now that Schneider has accepted me as a solar installer, I've managed a single question, where is all the literature? I got that answer and shared it here:
https://forum.solar-electric.com/discussion/354567/manuals#latest
So, armed with this plethora of knowledge, my curves look like this on really good days. Just a couple passing clouds. What I like is the peak power and the narrowing of the seesaw game at onset and curtailment of PV production.
I'm curious to see how the curve changes over the next year. at peak output the sun is directly overhead and my panels are around 30 degrees. I'm expecting the peak output to broaden slightly over the next 2 months.2 Schneider XW+ 6848 inverters
2 Schneider MPPT 80 600 Charge Controllers
Combox
40 335w Canadian Solar panels, 13.4kW array on an Iron Ridge racking system
1 big ass 24-85-27 refurbished forklift battery w/1430AH -
Hot Rod,
OH YAH! Way lots better, that is enviable, there is a learning curve and you are climbing up there.
TD.....backwoods guy fron Alaska
p.s. I think you win the bet, what do I owe ya!2 Classic 150, 2 Kid, 5 arrays 7.5 kw total 2ea. 2S6P Sharp NE-170/NE-165, 1ea. 12P Sanyo HIT 200, 2ea. 4/6P Sanyo HIT 200, MagnaSine MS4024AE, Exeltech XP-1100, 2 Banks L-16 battery, Rolls-Surette S-530 and Interstate Traction, Shunts with whizbangJr and Bogart Tri-Metric, iCharger i208B dc-dc buck/boost converter with BMS for small form lithium 8S 16650 or LiFePO4, -
Thanks TD, I just needed some reading material. You've more than paid me in advice and knowledge alone. Let's call it even.2 Schneider XW+ 6848 inverters
Combox
