2 Shunts / 2 Battery Monitors ?????
tr0y
tr0y Solar Expert Posts: 99 ✭✭✭
Equipment question, I have a Midnite Classic 150 & Whizbang Jr battery monitor, I also have new in the box a Victron BMV-712, for the heck of it I would like to use both to monitor batteries.
Here is where I have questions, is they both need a shunt, the Whizbang JR attaches to the existing shunt and then the Victron monitor has a connector and board on its shunt. After looking at both shunts, it seems to use both monitor devices I would need to use both shunts due to different attachment methods for the printed circuit boards. Can I run these in-line, parallel ? And still get an accurate read ? Or is this a bad idea ? Thoughts anyone ?
  • Tecnodave
    Tecnodave Registered Users Posts: 437 ✭✭✭✭
    edited June 2019 #2
    I am using MidNite Whizbang Jr with a Bogart Tri-metric on the same shunt, there are detailed instructions as to how this is done in the literature  that comes with the Whizbang Jr.
    The Bogart Tri-Metric has small wires that attach to the small terminals, the Whizbang Jr is installed first, then the spacers, then the wires or board on the same terminals.
    I see no difference in stacking the two boards than the Whizbang Jr with the Tri-Metric wires  That said, I've never seen that Victron monitor, it should be no problem as they are both millivolt range voltmeters that read the voltage across the shunt
    Its a matter of using the longer screws and spacers that are provided with the Whizbang Jr. or a visit to the hardware stope for longer 6-32 screws and spacers
    Ace hardware has by far the best selection of small hardware such as this
    these monitors only read the voltage drop across the shunt and need no power from the shunt, it should be no problem to get the longer screws and spacers to stack the two boards, they will not interfere with each other. Keep  the two boards a bit separated
    I have two Classic's, two battery banks and two shunts with dual battery monitors for about 5 years now, never an issue with that setup.
    2 Classic 150, 2 Kid, 5 arrays 7.5 kw total  2ea.  2S6P Sharp NE-170/NE-165, 1ea. 12P Sanyo HIT 200,  2ea. 4/6P Sanyo HIT 200, MagnaSine MS4024AE, Exeltech XP-1100,  2 Banks L-16 battery, Rolls-Surette S-530 and Interstate Traction, Shunts with whizbangJr and Bogart Tri-Metric, iCharger i208B  dc-dc buck/boost converter with BMS for small form lithium 8S 16650 or LiFePO4,
  • Estragon
    As tecnodave says, they may both work off the same shunt.  Just check to be sure they both spec the same (50mv?) shunt.
  • Tecnodave
    Estragon,
    good catch......some shunts are 100 mv.
    And many BMS monitors--You can program what shunt they have (xxxmV per yyy amps).
  • mcgivor
    Whatever you choose, don't parrallel the shunts, that way each will read 50% of the current, assuming equal resistance for both.
  • tr0y
    @mcgivor
    Thank you, that was really what I was wondering.
  • Simonb
    Simonb Registered Users Posts: 1
    I just received my Whizbang jr and wanted to keep my AiLi meter and shunt. The shunt that came with it is a 500a 75mv but the whizbang one is 50mv. I guess in this case I should just add them in series since they are different. Would there be a preferred order of the two shunts?
    No--Not really any series order specific (assuming the two voltage sense leads are "floating"--If you only had one voltage sense lead and ground, another issue).
    I looked around--And I could not find anything from Midnite that said you could program for a different shunt--And nothing from AiLi that you can program for a different shunt--So at this point, unless in your manuals/experience that you can program for the "same shunt" (such as 500 Amps @ 50 mV for both)--You are stuck with using two shunts.
  • petertearai
    petertearai Solar Expert Posts: 471 ✭✭✭✭
    In series and  they  should work completley independent of each other.
