Interpreting Tristar MPPT 60 calculator results?
blueskies
Registered Users Posts: 54 ✭✭
This was the results of the calculator for my panels. I have four. Do
these results mean I can (barely) use 4 panel if run two of them in
series? And that 4 of them in parallel is out of the question? Thanks
for any input!
Select the nominal voltage which I believe you are using 24V, the results in the image are for 12V if I'm not mistaken.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
what if i stick with 12 v batteries? is that really bad?
(giving up on running the rooftop dometic ac on solar)
or maybe there's something to convert a 24v battery bank to run all the 12v appliances i've accumulated over the years? Much Appreciated!!!
The charge controller capacity is based on output current, so whether pv is wired in series or parallel makes little difference. Output current for 12v is 2x the current for 24v, so double the controller capacity is needed for 12v vs 24v.
I run two systems; a 12v one for smaller loads, and a 48v one for larger loads. There are DC converters available to go from higher voltage to lower. There are pros and cons to each (2 systems vs DC converter) approach.Off-grid.
- 228 Forum & Website
- 618 Discussion Forums/Café
