Heating a house
inbyte
Registered Users Posts: 1 ✭
Hello guys,
I whis/think to heat a house (200 m2) like this: 2-3 presurized water panels, 3-6 kw power panels and 4-6 kw wind turbine. All this directly heating (without a battery bank) a water tank of 1500-2000 liters. I'm new in this kind of stuff so if some of you can help out if its duable and what is needed in the arrray to work (DC water heater or AC - more efficient to transform to ac or to leave it to dc, etc.)
DC at higher voltages become problematic in that it will arc easily. It would be more efficient though.
An integral part of my solar system is my wood stove!
As a start, I'd work out the design heating load. This will be a function of local climate, and house construction details (eg. type, size, and orientation of windows, insulation, etc). In a very mild climate and/or very well insulated structure, solar/wind powered primary heat might be viable (with something like Photwhit woodstove as backup).
Solar is marginal though, as heat tends to be most needed in winter, when the sun is low and days short. In my location (Canada), winter (Dec) sun only provides ~2kw/sq.m/day on average, so it would take a very large array and huge storage tanks to handle the heating load.
Small scale wind is also marginal in most locations, unlikely to be viable unless average wind speeds are > ~30-40km/hr and terrain is free of obstructions (trees, houses, etc.).Off-grid.
Guessing,
http://www.solarelectricityhandbook.com/solar-irradiance.htmlBrescia
Measured in kWh/m2/day onto a solar panel set at a 44° angle:
https://www.timeanddate.com/weather/italy/brescia/climateJan Feb Mar Apr May Jun 2.61
3.70
4.63
4.59
4.97
5.30
Jul Aug Sep Oct Nov Dec 5.52
5.32
4.48
3.28
2.49
2.08
Looks like a Mini-Split heat pump system might be interesting--Electrical energy wise, people have pretty good results with down to near freezing with them. And you get A/C and humidity reduction in summer, if needed.
If you have the land and a sunny spot, there are folks that have built fairly big collectors and water storage for their winter heating:
https://www.builditsolar.com/Projects/SpaceHeating/SolarShed/solarshed.htm
If I guessed your location correctly, you don't have a lot of solar (northern Italy, mountain region?).
In times past, people were really looking at ground sourced heat pumps (drill wells for water, bury piping, etc.)--But Air Sourced heat pumps (typically mini-split systems) have done a very good job of both cooling and heating.
Very roughly, heat pumps can harvest more energy down to near freezing, than a simple electric resistance heater.
Solar Thermal (water) systems--You run the risk of becoming a plumber (keeping pumps running, water leaks, freeze damage).
