What law on batteries
billybob9
billybob9 Registered Users Posts: 141 ✭✭
Watt's Law I=P/E
                 A=W/V
                 A=100W/15V
                 A=6.6A
So I took my Load Tester and clamped it onto my 12v battery ( Two 6 volts ) terminals. Then connected my 100W solar panel to the terminals. With full sun for 8 hours I EQ my batteries. 5 year old batteries why not give it a shot. Big time improvement ..
    Not sure what you think you are showing?
    The batteries are charging, Not sure why you would use the load tester to measure the voltage while charging?
  • billybob9
    The charge of the batteries were 12.3v so the 15v shown on the load tester is the difference that I monitor as it's charging. With the caps off the batteries I can see the bubbles and tell which cells are worst.
