battery life
Plucka
Registered Users Posts: 130 ✭✭
Trying to find out how long will my lithium batteries last at full capacity. What does capacity mean -amp hours or voltage ?.Daily discharge is to 13 volts and average recharge is 13.5 to 13.6 recharge and sometimes up to 14.4 volts
You can think of capacity as amps at the batteries voltage, of as watt hour by multiplying the amps x the voltage.
So a 6 volt lead acid battery has a capacity of 220 amps, or 6x220= 1320 watt hours. We often qualify the capacity by saying 50% usable. and if pushed you could use 80% but not very often.
With lithium you can do the same thing, most will say 80-90% usable capacity. Some will suggest reducing the max charge to preserve longer life.
Thanks -I now understand capacity.
