State of charge
Using a tablet there is a menu list in blue on the right, not seen on a phone it would appear, try tapping the 3 bars to the left of the Wind Sun logo..... just a guess on my part, I would expect it's there somewhere but I've never used a phone on this forum.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
I think you have to click on "full site", to edit signature... I didn't find it on mobile version either.Off-grid.
Over on the lower right is "signature settings"... You can also click here and edit directly (this link works for any member to edit their personal signature):
https://forum.solar-electric.com/profile/signature/
Thanks for the link BB. And you guys are right I'm sure. If I were to open the site on my computer, I'd probably find the options I was looking for. Thanks all.2 Schneider XW+ 6848 inverters
2 Schneider MPPT 80 600 Charge Controllers
Combox
40 335w Canadian Solar panels, 13.4kW array on an Iron Ridge racking system
1 big ass 24-85-27 refurbished forklift battery w/1430AH -
You are correct. The Mobile Version of the website has a lot fewer options/controls.
Sometimes, in FireFox, I use the FF pull down menu and click on "desktop" website version to access the extra options.
I may not move quickly, but I do move.
Signature fixed and avatar too.
-Jason2 Schneider XW+ 6848 inverters
Combox
