Any problems with this setup?
cmduran
cmduran Registered Users Posts: 3
Hello,
I am about to install (6) 180W Grape Solar panels with a Magnum PT-100 controller on my motorhome (9.15 amp, 24.06 VOC). I was going wire them all in series. Anyone see a problem with that configuration? I decided on wiring them all in series after talking with a Magnum technician who said that a 2X3 or 3X2 configuration would be delivering minimum voltage to the controller which might cause error codes. Does that make sense?
Also after reading a jillion posts on it, I'm still uncertain about what gauge wire would I need.
Thanks,
--mike
    Welcome to the forum Mike,
    What is the voltage of your battery bank?
    It is sort of difficult to find the Vmp/Imp rating of these panels... They appear to be 36 cell panels which would put Vmp~18 volts. A perfectly good "12 volt" panel if used with a PWM supply on a 12 volt battery bank (or higher voltage if put in series).
    For MPPT type charge controllers, you need to look at the ratings needed to operate your MPPT controller... Specifically, the MPPT operating range and the Vpanel never to exceed voltage.
    Solar panels are "imperfect batteries"... Their operational voltages (Voc voltage open circuit and Vmp voltage max power) fall as their cell temperature rises, and increases as the cell temperatures fall.
    So, you need to look at the Vmp-array range for the controller... Typically Vmp-array-hot --- As Vmp falls as the array is in noontime sun in a hot/windless day.
    For for Voc which rises in cold weather, you need to make sure your Voc-array-cold does not exceed the the Vpanel-max for the controller.
    The Magnum manual is here:
    https://www.magnum-dimensions.com/pt-100-mppt-charge-controller
    And you need to look at page 17 (PDF page 26) and there is a chart at the bottom. So, first we need to have your battery bus voltage. I.e., 12 volt battery, Vmp-controller runs from 60-187 VDC. Very roughly, in a hot climate, your 6x panels in series would be:
    • 6 * 18 volts Vmp = 108 Volts Vmp-array-standard-temperature (cells ~75F)
    • 108 volts * 0.81 high temperature derating = 87.5 volts
    Which is still over the 77 volts Vmp-min needed for a 48 volt battery bank. All is good there.
    You also need to look at the Voc-cold for these panels... On the next page of the manual, are the calculations needed for both Vmp and Voc vs Temperature calculations. But just from looking at your Vmp and Voc panel ratings, you do not have any issue with Voc-cold and the 188 Volt shutdown voltage.
    The wiring question... There are two questions. One is the maximum current on the wiring from the array... And that (appears to be) the Ioc (?) ~9.15 amps
    The NEC (national electric code) allows 15 amps on a 14 AWG cable (with proper insulation, etc.). And if the cable is exposed to sunlight, it needs to be UV/Weather rated cable too.
    The other calculation is how far is it from the array to the charge controller/battery? Longer wire runs, you want heavier cable so you have less losses. Typically we design for 1% to 3% maximum voltage loss.
    Note that placing all off your panels in series allows you to run much smaller (cheaper) copper cable from the array to the battery bank--One of the major reasons to "like" MPPT controllers and running "higher voltage" solar arrays.
    So, how far is it from the array to the controller?
  • Estragon
    One potential issue is if you have any vent stacks, antenna, etc on the RV roof that could cause any shading. Even a thin shadow from an antenna or overhead wire near one panel can substantially reduce output for the whole string.
    Panels in series is great - for fixed installs with no shade
    If anything on the roof, shades any of the panels at any time, even a small shadow (like from a pencil) will shutdown that segment of the panel (usually bypass diodes split the panel into thirds) and your output drops off. With enough voltage from series panels, harvest will slow, but not stop
    Does anyone have information on these Grape panels?
    They seem to be missing the standard ratings and information that we see on solar panels (no Voc/Vmp/Ioc/Imp, no NRTL, etc.). The use of a blocking diode (nobody does that any more, unless is translation issue and they are using by-pass diodes--Which are very much needed in this series array application).
    At this point, I would be buying another brand/model of panels unless there is a data sheet out there with the missing information/clarifications on diodes.
  • cmduran
    Wow. Great info! That is so helpful. And it's good to hear that I seem to be on the right track. It is a 12v system. The cable will be about 20-25' (say 30 to be sure).. I was looking at some wiring calculators and that seems to come out to about an 8 AWG cable?
    --mike
    8 AWG (one way run for this calculator), 30 feet, on a Vmp~108 volt array and 9.15 amps:
    https://www.calculator.net/voltage-drop-calculator.html?material=copper&wiresize=2.061&voltage=108&phase=dc&noofconductor=1&distance=30&distanceunit=feet&amperes=9.15&x=0&y=0
    Voltage Drop Calculator
    Result
    Voltage drop: 0.34
    Voltage drop percentage: 0.32%
    Voltage at the end: 107.66
    Actually, way overkill.... 14 AWG:
    https://www.calculator.net/voltage-drop-calculator.html?material=copper&wiresize=8.286&voltage=108&phase=dc&noofconductor=1&distance=30&distanceunit=feet&amperes=9.15&x=60&y=15
    Result
    Voltage drop: 1.39
    Voltage drop percentage: 1.28%
    Voltage at the end: 106.61
    Would be OK too.
    If you ever add more panels (Larger array), you could install the heavier cable now, and just add another parallel string (or many, with a combiner box) down the road.
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,182 ✭✭✭✭✭
    Here's the specs.
    Details
    Solar Cell
    Monocrystalline silicone 156x156mm
    Number of Cells
    36 (4x9)
    Size/Dimensions
    1480mm x 675mm x 35mm (58.27” x 26.57” x 1.38”)
    Weight
    12.0 kg (26.4 lbs)
    Front Glass
    High transmittance, low iron tempered glass with enhanced stiffness and impact resistance.
    Frame
    Anodized Aluminum
    Junction Box
    IP65 Rated
    Connectors
    MC-IV comparable
    STC Maximum Power (Pmax)
    180 W (0%, +3%)
    STC Optimum Operating Voltage (Vmp)
    19.67 V
    STC Optimum Operating Current (lmp)
    9.15 A
    STC Open Circuit Voltage (Voc)
    24.06 V
    STC Short Circuit Current (Isc)
    9.77 A
    STC Operating Module Temperature
    -40 ºC to +85 ºC
    STC Maximum System Voltage
    600V
    STC Maximum Series Fuse Rating
    15 A
    STC Power Tolerance
    0%, +3%
    Nominal Operating Cell Temperature (
    46 ºC ± 2 ºC
    Temperature Coefficient of Pmax
    -0.38 %/ºC
    Temperature Coefficient of Voc
    -0.28 %/ºC
    Temperature Coefficient of Isc
    +0.04 %/ºC
    Selling Unit
    Each
    Thank you LH2,
    Anything about the diodes?
  • cmduran
    It does have bypass diodes. It's this one:
    Thank you CMD,
    Bypass diodes good. Blocking diodes not needed and usually not wanted.
